Spent all day welding and cleaning crap off the bubble.
I am paying the price for using the stripper. It is messy and probably impossible to get completely off. This sucks
On a better note the trailer is coming along. Photos 1 & 2 show the hold downs. I will mill a slot in the plate on top for the hold down bolt to go through.
Photo 3 is the bracket under the bed that the bolt will go into. In the bottom of Photo 2 are some steel plates with holes. These will bolt to the underside of the bracket, you can see the holes. I will weld a 3/4" nut to the plates for the bolt to screw in to.
