I am back at the computer. I have been working but have not made any entries, why you ask. Because I have been doing the same )&&^%&%*& thing since the last entry. Trying to get the protective coating off the bubble. Photo 3 show where I am tonight. I gave up counting but I suspect I am at least 25 hours into it. What you see on the outside will not come off. I am probably at 15 min /sq inch. At this rate I will not live long enough to get it all off. I think it was sprayed on to thin.
I got the call from Delane yesterday that my rotorhead will ship on Monday.
I should also get my Power Flow exhaust next week
Photo 1 is the end of the governor linkage that attaches to the throttle bell crank. The turned down area goes in the bottom hole.
Photo 2 shows the counter weight spring for the collective. Notice that the cables run inside the springs. This is a PITA because the cable has to be slid between the coils. As far as installing it, a set of car "drum brake spring pliers" worked great.
