Brief Description: Install Govenor and Bubble (con't)
Got the governor installed and the wires hooked up. Only problem is that I don't know which way to hook the 2 wires going to it. I have a 50/50 chance of getting it right. If I get it wrong it will run backwards.
HELP - Still no luck on the bubble. I don't know if it sat to long and took a set or what. At the front I cannot get the rearmost clips on. The bubble needs to come down about 1/2". There is way to much strain on the little clips around the door opening. I am out of ideas I guess I will call the factory tomorrow and see if they have any.
