Got a full day in spent most of it redoing things. As I mentioned earlier I installed the fuel flow sender improperly. You can see from the picture below that now the outlet is higher than the inlet. I also made for neater hose runs. You can see the three wires hanging off of the sender. I cut the terminals off and used the same type of connectors I used on the fuel probes.
I got the oil tank in place and all the lines run. I used the hose barb fittings on this, I may change them out later if it bothers me enough.
I am sure I did more than this but I am writing on Monday night and don't remember. I just know I was at it all day.
