Well I finally decided that in order to move forward I needed to do some cleaning up. Way too many wires laying around. As I mentioned earlier I am using the "lacing" technique instead of tie wraps. It looks much better, is faster and I have seen 50 year old airplanes with the original lacing still in place.
I also figured out how I can go ahead and install the instrument pod without the floor in place. With that I decided now was the time to go ahead and hook everything up. I know that some of my wire labels came off. I need the wire bundle loose in order to track them too figure out what the are.
I also found an oops as I was lacing my Nav Lights. I had hooked up the Buzzer wire to the Nav. Not paying attention.
