Wired up the solenoid board. Need to figure out how to ground the Master Solenoid. The feet are encased in rubber for insulation. Call Sean. Found several wires that I am unsure where they go. Call Sean. Found a mislabeled wire, cut apart lacing, find out that it was right, found out the unlabeled wire was a ground, sigh.
