I received my rear fuselage parts shipment so I spent today unpacking and do an inventory of parts I received. I was given a heads up by Rachel the box would contain a lot of styrofoam peanuts used in protecting the parts. To avoid having to sweep up a huge pile of this material, I laid the box across my table and carefully opened one end and began dumping into the trash can pictured below. I ended up with a 55 gallon garbage bag full and the trash can about 2/3rds full; so you have been warned !! The 3rd picture shows the longerons, elevator push rod, aileron push rods, the bulkhead and turtledeck formers and the elevator push rod tunnel. A Big Word of CAUTION: Carefully go through the packing peanuts you have dumped out as there are some small packages hiding in there. It would be a shame to unwittingly throw good parts in the dumpster. I was lucky, found mine before the peanuts went to the dumpster.
