Finshed all the perimeter tapes! A bunch of work, but the tail is covered. Put all the pieces in my "drying room", the bathroom in the hanger and turned the heater up to 85. Seems to put the final set on the Stewart glue, the hanger is kept at 65 and it was 29 thiis morning outside. Took the first stab done and went over all the tapes with the small iron on the edges. Worked over the lLE and TE tapes where there seemed to be ripples and got them out.
Stirred up the EkoFill and put the fbrushed cross coat on the stab, Sure brings out all the defects. Will cook in the drying room tonight and see what I can do. Expected this, the first coat of primer is always a interesting time. Usually means the start of work to get a finish no matter what you do.
