Bruces Web Site
Date:  11-22-2016
Number of Hours:  4.00
Brief Description:  Trim wire and start tail
Drilled 3/8" holes into the right side former and pulled the trim wire. About 3' out the back, rest up front. Put two snap bushings left over from the RV-10 build to protect the wire.
Started on the tail. Checked the fit of the elevators/stabs. Hinges were done by factory and it all seems to line up properly. Drilled the one hole in the elevators for the control horns and installed nutplates.
