Continued and finished up going thru the parts list. It was all there except the four things identified as backordered. Split it up into seperate boxes, fueselage, wing and other or unidentifable or both, covering supplies, pipe fittings and Rotax. . Stapled the other box to the side of the storage box, this is a geat way to store the parts. You can see the part and leaving in in the bag gives you the part number. Will do the fues parts tomorrow, leave the wing til I start on it.
Completed organizing all the screws, nuts, bolts and rivets and etc. ty-pehardware into four fishing storage boxes.
Put the fues into the stands I built from the plans on the website. Discovered that the fin just scraped the bottom of the frame, so cut the vertical and spliced in 1/2" which gave just enough clearance.
Tomorrow more cleanup and then actually start real construction.
