Removed all clamps and wood strip. Cleaned up some glue that got on top of the wing wrap. Taped off the filler area and put on Bondo. After cure, sanded down until the tape was being removed, took off tape and did final with some 320 paper.
Retaped in some areas that needed a bit more work and repeated the process. Looks good and is now done.
