Put the final brushed coat of Ekofill on the tail surfaces. Came out Ok. Putting the hanger temp up to 72 helped the drying process quite a bit from 62. It was 32 outside but the hanger is well insulated.
Started putting the gear on the fues. Files the gear spacer bushing slightlly per Rans tech. Need to plan the next parts carefully, I plan to put it on the main and then do the nosegear and then take it all off.
