Continued covering the stabs. Had to remove the fabric from the top of the second stab, should have been on the bottom plus had a couple of not good things. The stuff was not easy to remove, but the Stewart glue came off easily with Acetone. No worry about the fabric anchorage being an issue unless you land in a lake of Acetone
Put the bottom fabric on the second stab and prepared it for the top. Ironed the first stab to 300 and then 350 degrees and it came nice an taught. Did the double sided tape, plastic strip, burn holes for rivets and trim off the burn stuff. All went well, but slowly for the first time. Riveted the ribs and put 2" tape over the rivets.
Getting better with each application, I judge how well it went by the amount of glue on my fingers when done.
