Completed the trim switch. Drilled hole in pilots stick for wires and put in. Did the rest of the stuff to complete the sticks. Took about 10 tries to get the adjustment down so both were parallel. The rod end was screwed almost all the way in when it was right.
Put in fues with clecos and then went outside to mulch leaves for the garden. Sun was shining in Oregon!
