Gathered up the rudder pedal parts, drilled, deburred and riveted them into four pedals. Put them on the rudder bars with the washers, etc. Put in the airplane and then took them out and arranged them so the nosewheel pickup and rudder pickups were in the right places. Got out a master cylinder and put it in place to check that all was correct, and it is. Ready to finalize.
When doing the many parts in the pedals, I tried the usual to get the lables off, acetone. Was going nowhere and there were 12 parts. Put them in a small container with hot water and after a minute or two, all the lables just came off easily. Left the glue, but it comes off with acetone. My only issue with the kit is solved!
