Removed the aft baggage box, disassembled, deburred and trimmed the parts. The Rans part sticker is not the nicest thing to remove. Takes a fair bit of acetone and rubbing and then it can be scraped off and the last bit of glue cleaned. My biggest complaint to date, so I am still happy.
Riveted the box together and put in the aircraft and started fitting the forward box. The sides took a bit of time to figure how they laid with the rest. Got the station 2A(?) closure out and put it and the bottom of the foward compartment in with tape. Ready to start drilling the #11 mounting holes and making the bottom angles. Think I will "jog" the bottom angles where they lay under the aft angles. Should make it easier to remove the forward part for maintenance.
