Worked on small details. Punch list now has 17 items, two complete. Made magneto cooling air line and put on tips for real. Made up a new sheet of decals for the NO STEP signs and the fuse position, now with fuse size. Clear coated for installation tomorrow.
The oil company sent someone out to pick up the two cases of the wrong oil and promised the correct mineral oil will be here Friday. Good service, if the right oil shows up.
Worked the Service Instruction on how to drain the preserative oil our of the engine. Removed the bottom plugs and a lot of oil came out. The plugs werr full of oil, so I celaned them and put back in after rotating the prop to force oil out of the cylinders. Cleaned the injector inlet screen, per the S.I., but it had no oil. Drained the oil pan, still has oil dripping out after about 3 hours. Thick stuff.
