Put in rear bulkhead after adding a small hole and grommet for the battery charging cord. Have a desulfaniting charger and it needs to be used to keep the battery good, so just open the baggage door, plug in the charger.
Made the other passanger rug. Put velcro on the bottom and carpet tape around the sides where it goes up the side for 3" and installed. The carpet tape is to hold it up and the velcro anchors. Did both passanger seat wells. Cut the rug for the left front. Laid out the rear templates to verify there fit and prepared to cut.
