Sent a couple of hours on the computer making up the panel and other lables in Word. Printed out, cut out and taped onto the panel and other places. After a couple of modifications, printed out on Avery Clear {?} project paper. Cut a sample out and put it on the plenum which is the same as the instrument panel. Looked bad, not clear and totally different level of shine. Researched some more and orederd some decal paper that requires clear coat from a spray can.
Worked on the seats and discovered I need to make a slight change to the front bottoms to clear the aftermarket seat adjustor. Marked both bottom covers and turned it over to my wife.
Checked on how the velcro would work on the carpets and discovered it is not very good. Holds the material too far out due to its thickness on the vertical edges. Decided to try carpet tape and see if it stays removeable for maintenance.
Put on the Flightlines baggage door cover, great, looks good and has wonderful storage for misc. things.
The year is not starting out real well, but had black-eyed peas for dinner, sure to make this year a success.
