Removed and reinserted the four wires in the Light Speed input plug. Worked, but only on one coil. Adjusted the pickup, which was about 1/16" too high and it then worked on all 3 coils. Phased the coil wires and marked the coils as to their wire and cylinders. Put the Dsub housing back together and put it in correctly.
Started running the coil wires and putting on clamps.
