Where the temperature sensor wires come out of the firewall and go over the motor mount, there is the potential for rubs. No movement, but I installed some baffle material around the wires where they are close or touch the motor mount.
Connected the left side EGT and CHTs. Left about a 6" service loop in each wire. The loop and connectors are all covered with heat shrink and are hard to see in photo 2. The whole mess of them will be tied and then a clamp placed at the bottom with a loop to the motor for movement.
Turned on the Skyview system and all the sensors showed about 55 degrees, the temperature in the hanger. It was 29 outside with snow on the ground. Picture from inside the house, hanger is to the right. . Big gas bill
