Bruces Web Site
Date: 2-27-2013
Number of Hours: 4.50
Brief Description: Avionics, doors
Avionics, completed design of the schematics except for the intercom/radio. Will do that one after I specify the harness with Stein.
Spent more in the last four days on avionics than our first house! The full dual Skyview system is purchased, a ton of wire, switches, wigwag, lights, fuse panel, d sub connectors, custom printed circuit board, and a labeler to print heat shrink markers that UPS just delivered two minutes ago. Ready to start when the restt gets here.
In the meantime, put the cabin top back on and bolted the doors on. Did some light cleanup on the left door pin holes and it worked easily and very smoothly. Installed the McMaster seal on the door as a trial. It fit very well and the door closed without much effort. Got good compression of the seal all around. It was worth the time!
Started fitting the Plane around center latch. Drilled holes for the strut mount.
