Brief Description: Hang right door, sand left to fit again
Installed backup plate for door lock in right door, mounted lock and reassembled the door latch system. Hung door, mounted front and rear plates on fues. Latches "hard", better than loose. The issue is in the holes in the fues that are tight. After everything is done, I will work on that issue.
Sanded on the left door until it fits with almost a constant 1 business card clearance. I know from expereince that it won't stay, but at least it is Ok now. Will need some filling around the top rear curve, for some reason it sticks out about 1/32" while the rest is close to perfectly flush. FIBERGLASS!!!
Marked up the gutter for trim, and decided to quit for the day. There will be a whole bunch of dust in the air tomorrow.
