Brief Description: Glue rt. door, latches, trim left
Worked on door latches. Completed all work up to installation.
Glued together right door. Went well, used slightly looser epoxy mix.
Removed left door. Trimmed window and outside to a shade outside of the scribed line. Looks like the outside piece was about 1/8" to the rear of where it should have been. The front edge is just about right and the rear has almost 1/4 to go. That was close. Need to shape up the edge of the cabin top and then start final trimming the door.
