Bruces Web Site
Date:  1-15-2013
Number of Hours:  2.50
Brief Description:  Study and decision time
Now that the door skins are here to see, I studied the seal situation. Looked at a lot of VAF and Matrionics posts (great resource!!) to see what others have decided.
I think it is obvious that the best answer is to go with the McMaster Carr seals. Firstly it gives you some leway in trimming the canopy cover. The Vans seal is more fussy in this. It looks like you can cut to clear the inner door frame, leaving the dimensions of gutter in the video pointed out by Leffler. Trimming the edge and adjusting to get the door clearance and base for the seal to seat is
straight forward glassing and sanding, several times, I am sure. Secondly it covers up the raw edge of the canopy cover. Lastly, the seal will hold on with a mechanical clamping action rather than adhesive.
Ordered seals from M Carr. Marked trim lines on all the door skins and the canopy frame. Tommoow will be a marathon of dust..
