Brief Description: Csk mount holes in wingtip, wire wingtips, rt. win
Made a guide and then counterskunk all the holes on the wingtips. Put one on with the screws to see how it came out, looks Ok. One wingtip does not line up with the aileron by too much. Looks like I will have to remove the aluminum rib and put it on again. Did it when the tips were clecoed in place and looks like it shifted slightly.
Wired up AeroLed strobe/run lights and installed in tips. They use Molex plugs with which I do not have much success. After completing both, the left would not plug into the wing plug. Pulled on the wires and one came out. Will order some good AMP connectors and do the whole thing over again.
Molex is sold a Radio Shack, a very positive reason for not using them!
