Brief Description: Wing tips, aileron servo wire/mount etc.
Trimmed off the end of the taxi/land light mount tube. Glued in the mounting ring and mixed up some micro to clean up the end and inside of the tube.
Mounted the aileron autopilot servo. Built and riveted a 9 pin Dsub bracket to the wing skin that has the AP servo wires. Put in push rod, servo brace and safety wired all the attach hardware.
Put a Dsub on the AP cable and put a clamp on the edge of the cutout to hold everything away from the moving hardware.
Light Speed ignition system showed up. Very well done package. Dynon relaased the radio for shipping on Monday, have to see where my order is with Stein.
