Comleted reinstallation of the flap drive. Works much better than the first, at least it sounds the same going up an down.
Continued lacing wire. Did most of the leftt side up to the EMS connector. Put on two cable clamps. Checked the EMS wires and which wires were to remain as spares. Discovered one wire switched to the Light Speed rpm pickup with the manifold pressure. Opened up EMS 37 pin Dsub and switched the two wires. Also removed four wires that will not be used, Voltmeter 2, Fuel Flow 2, RPM left mag and RPM right Light Speed. Left open for the two thremocouples that will be here soon.
Removed the Skyview to hub cable that I rebuilt with longer wires, Tied the wires and installed the Dsub hoods to complete. Need some additional Dsub hoods for the other wires, ordered from DigiKey along with some dust shields for when the Skyview stuff is removed and fiberglass is being worked..
