Built doublers for both com antenna and installed. Built one end of the antenna for Com2, the PAR100EX transceiver.
Wired in the ampmeter to see what the system draws. The dual Skyviews, Transponder, ADSB and GPS were a total of 5 amps. Not a lot.
Discovered that the ADSB reports itself as failed unless the transponder is on ALT. Since the government system receiver is not seeing my transponder, I don't get customized traffic, only can see ships putting out ADSB signals. The map screen shows ADSB as "Partial" most of the time, sometimes just going to "Full" on occassion. It does show all the weather stuff which is well integrated into the rest of the Skyview system.
