Brief Description: Panel wires/plug, firewall forward power wires, ma
Copmpleted wires on front panel to its Dsub connector. Tied wires and added a brace to support the wires to the 4 lights.
Ran wires from the EMS distribution bus for +5V power and ground to the oil, fuel and manifold pressure instruments firewall forward.
Started making the cables to run from the displays to my hub. Replaced the USB cable and shortened up the battery wires to the factory hub. Cut all wires to the same length.
