Brief Description: Mount termainal boards/stick connectors, wire trim
Comepleted wiring the stick plug on the left side terminal board and checking out pin-outs. Did the same for the rignt, only two pins, co-pilot PTT. Installed both terminal boards and mounts. Modified the seat brackets that mount on top of the gear mounts so a small wire bundle will pass between them and the spar.
Wired all the connectons on the left, trim, board and checked operation of the elevator trim. Worked! Still need to tie the wires, will wait until the right side, autopilot and PTT switches are done.
