Drilled and installed both radio trays. Trimmed glove box that goes under them to size. Will have to put it in(from the back) before installing harness so ordered a yard of 60" wide black Ultraswade fabric for the top of the instrument panel and inside of the glove box. $69/yard. Used it on my -6A panel top and it is still like new after 15+ years.
Removed my Skyview hub and fixed the one mistake I found by cutting a land and soldering in a jumper to the correct position. Added lables to the front side and put back in AC.
Decided on final location for the PAR100EX transceiver. It will mount to the skin via a mounting plate behind the door opening. Designed and built a test piece to anchor a screw in the mount so it can be mounted flush with the inside of the skin and the nut installed from inside the AC. The test was a success and production of the actual thing will be tomorrow.
