Brief Description: Antenna, mount trnasponder and ADSB rec.
Mounted the transponder and ADSB receiver antenna. Transponder up front and ADSB near the flap actuator.
Drilled holes in the tunnel sides up fromt for the transponder and ADSB receiver mount. Since they are very near the rudder pedals, they need to be flush or as least low profile screws on the outside of the tunnel. The trnasponder mount was designed to have the flush screws on the inside and there was not room enough for a nut. Had to build a extender to let me put a nut on the inside of the transponder mount. Took about 2 hours.
