Bruces Web Site
Date: 3-18-2013
Number of Hours: 4.00
Brief Description: Mounting things
Continued mounting things. First picture has the two Skyview backup batteries, the wig-wag controller, Van's door warning light relays, a 15 pin Dsub and a dimmer. All to the center panel. With the displays out, all are removeable because they are nutplated and screws can be reached from the front.
Mounted the engine monitor system on the left panel, this has 3 cable runs, a 37 pin, 25 pin to the motor and a system cable. Nutplated also. Only thing missing is the Lightspeed box, it will go on the firewall later.
Received my two little USP pass-thru things in a box big enough to hold a radio. They are about 1" square. What a waste of paper.
Since almost all is mounted in the panel area, it is time to start painting the panel tomorrow, and mount the four antenna, transponder, ADSB receiver and com transmitter remotely.
