Completed fuse panel. Little angle bracket at top in photo that holds the fuse panel upright took four tries to get right. Very simple, ha!
Cleaned up holes in panel for Skyviews and put them in. Drilled the mounting holes and installed nutplates. Put in and put panel in aircraft for photo. Got out one of the system cables to see how they fit and discovered that it was not long enough to reach to my location behind the fuse panel where the Hub will be placed. Best laid plans .... etc and some other words.
The small screen cable is close enough to work. So either add about 1' to 25 wires and make 25 chances to create a problem, or. Decided to call Stein Monday and see what a new cable will cost, slightly longer. I believe he makes them for Dynon, so it should be easy for him. I can send him one to return to Dynon for credit.
