Designed Hub for Skyview system. Will allow pluging in all the related devices, power ins amd outs required for the system. Pad2pad free PCB designer is relatively easy to use to do this sort of thing. Need to run one more check on all the details before clicking on an order. About $160 for one board, or 230 for 10. Will order 8 where the price is about $30 each. Now I can order the solder in Dsub connectors and a bunch of other things from Digikey.
Had a good quote for all the Skyview and other equipment. Will send the check in a couple of days when the Financial Advisor has finished liquidating a bunch of investments.
