Brief Description: Wheel fairings, nose gear fairing
Cut down fairings, located and drilled mounting holes for bottom ones. Uppers were trimmed and the holes put on later. Mostly sheet metal screws with one nutplate on the wing. Appears that they will work well, all need some work, but will do it later.
Started on nose gear faring. Built standoffs, cleaned up mounting brackets and installed. After about 15 tries at bending the mounting lugs and trimming around the wheel, got it located properly. Drilled the mounting holes, tapped and installed with flox. Spent some time stuffing more flox into the gaps thru the front.
