Brief Description: Motor mount, fuel lines, wheels
Put on motor mount. Torqued and installed cotter pins on the six bolts holding it on.
Made a new fuel line from the tunnel to the outside and installed along with the other one made previously. Put in top parts that hold the fuel and brake lines in place.
Am planning to put it on the gear this weekend. Started on main wheels by removing the bearings for greasing. Will use high temp disk brake bearing grease.
