Brief Description: Front cabin brace, GPS receiver and wiring
Drilled holes to run GPS wires up the canopy brace. Bottom hole is inside the tube and upper is just above the flat plate. Cut the wires and laced the portion that is under the dash and runs thru the canopy brace into the Aerosport overhead. Drilled holes for the GPS antenna and wire run with bushings.
These wires will have a pari of Daubs to connect the GPS antenna to the aircraft wires inside the Aerosport overhead. The pins can be removed from the GPS Dsub and pulled out so the antenna can be removed for finishing and painting of the cabin top. Installed the pins and plugs.
