Completed detailing out the rug tamplates for the front, passenger and baggage areas
Maked the area in the fues where I missed the Zolatone and the flange area on the side panel that should have beem Zolatoned. Painted with primer and then touch up gun. Gun worked marginally well after reaming out the fluid hole in the horizontal position which is a problem in some areas. Used up most of the gas can, will have to get another.
Dimpled skin at cabin top. Countersunk the holes in the sides of the cabin for the dimples. Put top on and retreived wire from overhaed lights and pulled it thru the rear bulkhead. Can find no reason not to put it on for good..
