Brief Description: Complete dimple, reassy front and rear fues
Completed deburring join area. Dimpled skins and other things. Couple of places on front fues were a bear to dimple, tight.
Riveted on lower former and checked over everything for missing dimples, rough edges, etc.
Assembled front and rear. Did not go as easily as first time, most likely the skins having to go over dimples. Also one of the tabs on a bottom rib went under instead of over the bottom former. Could not figure why holes on that side would not line up. Finally saw it and corrected, everything lined up!
Installed bolts in longerons and torqued. Ready to rivet.
