Completed debur and dimple last part. Deburred and edged the skin. Dimpled. Primed the angle. Riveted angle and then assembled the complete section. Will be up away until needed to fit the cabin cover. When instrument panel is designed, can modify parts easily before final assembly.
Got help in riveting the last rivets on the bottom of the rear fues. section.
Pulled out tailcone and set it up for assembly. Just like everything else, it looks it will not fit, then one hole lines up, then another and then suddenly everything works. Amazing!. Clecoed front and rear fues together for drilling tomorrow. Big Airplane!
