Bruces Web Site
Date:  7-20-2012
Number of Hours:  4.50
Brief Description:  Main spar bulkheads
Started on forward spar bulkhead. The right gear mount did not fit. Checked it on flat surface and discovered that the traingular portion was rotated about 6 degrees. Would require tapered shims on every surface. Called Vans and will take it in on Monday. Will require replacement.
Worked on aft spar bulkhead. Plenty to do without the gear leg.
