Brief Description: Trim tabs, blue in ribs, Tailcone, longeron, assem
Completed riveting trim tab bottom spar. Made and glued in the foam ribs. Will sit for a couple of days.
Completed edges on all stiffeners. Drilled clearance slot in longerons and bent both. Assembled and drilled out bottom skin stiffeners. Put on right side skin, stiffeners. Hard to pull skin down to formers on sides. Finally got it right.
