Removed one of the panels from the motor home roll up door in the hanger. Quite an adventure,
Built a frame to fill in the bottom. Insulated the ends and mountedthe two exhaust fans on the frame. The fans have an external insulation block that is removed when painting.
Now to build a filter bank on the bottom end 2X4 and tie it to the fans.
