Went to the self service on the airport with two five gallon jugs. It was 26 degrees and windy, so by the time I filled them up, everything was frozen. Put five in the left tank and the fuel line to the injectors into the empty jug and turned on the pump. About 50 GPH if the flowmeter is near right. Plugged the line up and got 30 PSI on the gage. Turned off the pump and it went down to 29 in about 5 minutes. System appears tight, perhaps a small leak. Could not smell any gas. Pumped the tank dry and then repeated on the rightt tank. Same results.
Put all the screws in the bottom wing gap cover. Put the "NO STEP" decals on the wing flaps and did one more item on the checklist. Only added one, so gaining on it.
Photo out the hanger man-door. This is to go on for the next two/three days. Hope they can get my oil to me tomorrow.
