Bruces Web Site
Date: 1-8-2014
Number of Hours: 4.50
Brief Description: Control sticks, side panels
Installed both control sticks. Adjusted so they are parallel. Put on aileron pushrods, missing one rod end, I think I got a wrong rod end because the one left over is a 1/4" bolt.
Got decal paper for the panel lables. Made up a sheet and sprayed two coats of clear coat. Cut out one decal and put on the plenum as a test. Looks very good, have the issue resolved. Received seat belts from Vans today and a VAF data plate.
Continued installing all the interior panels. Using every other screw, etc. Finding some minor things to do and correct. All the side panels are installed, ready to do the rear wall with a penentration for a battery charger connect. Have a desulfating type charger and want to be able to plug it on and will have a loose plug in the baggage area, away from the door, to use. Also found where I can paint the 2" "Experimental" sign on the upper back panel.
Ordered the EAA Cerfification of Amateru built aircraft package on Sunday. Ready to register. The end is near, at least I am at the 95% done, 30% to go point.
