Bruces Web Site
Date:  1-2-2014
Number of Hours:  3.50
Brief Description:  Seat heaters, seats
The heated seat kits arrived. Removed the rails etc from the left side and figured out where the seat relay, controller and wires can go. The seat heaters were suppose to be 9" wide, but that is the heated part. It is actualy about 8.7". Figured out I could trim the sides of the back heater down to the size I need, just add some additonal double sided tape to hold it in place.
Glued the seat heater to both bottom foam. Installed one seat and put down the velcro. Added some #77 spary adhesive and put down the seat cover. Trimmed the back bottom cushion as described and glued it to the seat back with #77. Cut a couple of slots in the seat back for the seat heater cable and slid it over the seat. Put the velcro on the seat frame and ran out of time.
