Modified my manifold pressure sensor line routing. Got it away from the oil filter.
Started on the hinges that mount the cowl. Will be using Skybolt for the top cowl and nutplates for the bottom hinge. Made both side hinges, drilled, dimpled and countersunk. Started riveting and discovered that I could not reach some ofthe rivets near the motor mount. I didn't do this when the plans called for because I was waiting for the Skybolt parts.
Loosened up the motor mount bolts and pulled it slightly away from the firewall to be able to get the bucking bar behind the vertical tube.
Laid out Skybolts on the top. Will need to put the two lower ones on before putting the motor mount back.
