Brief Description: Finish wire pressures sensors, throttle, mix and p
Finished wiring and tying the engine pressure sensors.
Installed the throttle, mixture, prop and aux air door cables. Installed the firewall fire blocks and clamps inside the fues to hold them. Put a clamp on the manifold pressure aluminum tube.
